74LVT transition times: How low can you go?
Discussion in 'Electronic Components' started by Joerg, Mar 1, 2007.
  1. Joerg
    Joerg Guest
    Specsmanship seems to be on the decline. Philips/NXP is usually top
    notch but the family guide for their LVT series is, gasp, three pages
    short. Information about maximum transition times on inputs: Zilch.
    In an embedded application I need to slow down the /OE of a 74LVT244 so
    it turns tri-state fast but goes onto the bus slower, to avoid a brief
    contention when addresses change. Is it ok for that family to slow /OE
    by 200nsec or so via RC? It'll be the usual two resistor, one diode and
    one cap deal. Want to avoid adding another Schmitt here.
  2. John Larkin
    John Larkin Guest
    Sounds reasonable to me. Not a lot can go wrong here.
    John
  3. John F
    John F Guest
    100mV/ns and 1/2 µs are specified.
    I'd go with that solution.
  4. Hi Joerg,
    Philips used to claim Schmitt Ips on these ? (well, the LVC series )
    (but not everyone does..)
    Their LVC244 data says this:
    (as does the LVC2244A, which we have just used )
    " Schmitt-trigger action at all inputs makes the circuit highly tolerant
    for slower input rise and fall times." -
    -jg
  5. Joerg
    Joerg Guest
    Hmm, interesting, where did you find that?
  6. John F
    John F Guest
    Attention: He is talking about lvC and you about lvT!
  7. Joerg wrote:
    You can make a delay using something like 1G97.
    But the 200ns seems like an awful long time. Why would you need that?
    Vladimir Vassilevsky
    DSP and Mixed Signal Design Consultant
    http://www.abvolt.com
  8. Yuriy K.
    Yuriy K. Guest
    http://www.google.com/search?hl=en&q=phillips+lvt&btnG=Google+Search
    http://www.standardics.nxp.com/support/documents/logic/pdf/family.lvt.specification.pdf
    RECOMMENDED OPERATING CONDITIONS
    Dt/Dv Input transition rise or fall rate; Outputs enabled : <10 ns/V
    Not according to specs.
    http://www.standardics.nxp.com/products/lvt/pdf/74lvt2244.pdf
    9. Recommended operating conditions:
    Dt/DV input transition rise and fall rate; outputs enabled : <10 ns/V
  9. CBFalconer
    CBFalconer Guest
    Is that a CMOS package? If so, slow transition times will
    seriously increase the power consumption, and (if excessive) can
    actually destroy the chip. The reason is that at intermediate
    levels both the pull-up and pull-down components are on, and are
    fighting each other.
  10. Jim Thompson
    Jim Thompson Guest
    Sure is a _crude_ way to get a timing delay. Why not do it right ?:)
    ...Jim Thompson
  11. Genome
    Genome Guest
    This is standard practice when divisions of companies like Siemens or
    Philips get sold off, broken up or reincarnated. Ultimately all the useful
    data which you used to able to download as a single big book gets split up
    into lots of little pieces that are then smeared about the new abortion of a
    website and in the process a lot of it just disappears.
    It's either job creation, stupidity or job creation for stupid people. The
    final goal is to force you to contact an application stupid person using a
    stupid web form that is invariably hidden behind a registration stupid web
    form.
    If you want the information you might try it but invariably you'll become
    Mr Bum Bollocks
    Bum Bollocks & Co Ltd
    Bum Street
    Bollockshampton
    Just so you can say something like......
    Re your p/n 123XYZ
    I have just placed my order for 24,999,678 units with Not Your Company Ltd
    Kindest ETC
    Mr Bollocks
  12. Joerg
    Joerg Guest
    Are your sure the LVT is going? I am not too familiar with modern logic,
    as an analog guy I usually get away with 74HC and CD4000.
    Anyhow, this LVC driver doesn't look like Schmitt, it says 10nsec max
    transisitions on the inputs when using it at 3.3V. Our bus will not even
    be that fast. On purpose, for EMI reasons.
  13. Joerg
    Joerg Guest
    I could also do it with a 74HC14 but I wanted to avoid more chips.
    I might get away with 100nsec. There is going to be some intricate
    address decoding, more than just a 688 and a 154.
  14. Joerg
    Joerg Guest
    I had the LVT244 in mind (sans terminator), not the LVT2244. For some
    reason the NXP server doesn't find its data sheet anymore this morning.
    Arrgh. Well, at least Digikey has a few thousand of them.
  15. Joerg
    Joerg Guest
    Yeah, I know. If it had Schmitts it would be ok. Guess it ain't...
  16. Joerg
    Joerg Guest
    Yeah, it's sad. This moring the NXP server has become unable to even
    find the LVT244 datasheet. &*#^!!. Link broken. Sometimes it is
    unbelievable what people do to a formerly well-oiled machinery. What a
    great company this had been in the 80's. Sad.
    I stopped writing to top brass about serious issues a company has.
    Because they rarely listen. So I just quietly skadaddle over to the
    competition.
  17. Look at the dates on the data sheets, and the lack of a 'new' category
    on their web site.
    There were too many low voltage logics, and they seem to be slowly
    rationalising to two wide voltage familes, the LVC and the AUP
    It explicitly says so in the data (above) - so where you have a conflict
    like this, grab a device and try it :)
    Often they still spec a Tr/Tf, in order for all the timing to be valid.
    eg if they allowed a slow data rise, and a slow clock rise, then the
    threshold match comes into play - so they give a test tr/tf, which
    mitigates threshold effects, and makes all the ns specs valid.
    Just try one: Ramp the inputs, and measure the Icc and output - there
    will be a Icc/Vin relationship, that is not always given, and on
    some devices that can be what I'd call poor. Probably does not matter
    in your design.
    -jg
  18. Joerg
    Joerg Guest
    Thanks for the info, always good to know what's on the way to becoming
    unobtanium.
    Or maybe I just place a couple Schmitt inverters to, as Jim put it, "do
    it right".
  19. You could, (would cover more vendors), but to this Jim, using a part
    with hysteresis IS 'doing it right'.
    We've just designed in a Philips LVC2244 for that reason.
    To my mind, all logic should have hysteresis by default, but I
    do note that the new universal gates 1G57/58/97/98 all have hystersis.
    ( and the better CPLDs now have it selectable by pin )
    If you need to start using 'fixup gates', have a look at those
    universal gate series.
    With one of those, you should be able to save 2 if your passives.
    -jg
