741 OP_AMP Thermocouple
Discussion in 'Hobby Electronics' started by Robert, Apr 29, 2006.
  1. Robert
    Robert Guest
    Keeping the circuit simple as possible for maxium output voltage, if a
    thermocouple is conected to inputs pin 2 and pin3 is a resisor required
    between input of pin 2 to output of pin 6 for maxium output voltage or the
    resistor is not even required.
    In replace of the resistor can a conection be made between input of pin 2 to
    output of pin 6.
    Any sensor that generates its own voltage in mili volts can that be fed to
    the inputs of pins 2 and 3 or is a negative feed back required for maxium
    voltage output of pin 6
    Thanks Robert
  2. Ed-
    Ed- Guest
    assignment help is expensive, but you get wat u pay 4, hey!
    : Keeping the circuit simple as possible for maxium output voltage, if a
    : thermocouple is conected to inputs pin 2 and pin3 is a resisor
    required
    : between input of pin 2 to output of pin 6
    yes
    for maxium output voltage or the resistor is not even required.
    yes
    : In replace of the resistor can a conection be made between input of
    pin 2 to
    : output of pin 6.
    yes
    : Any sensor that generates its own voltage in mili volts can that be
    fed to
    : the inputs of pins 2 and 3
    yes but
    : or is a negative feed back required for maxium
    : voltage output of pin 6
    yes, otherwise the o/p will saturate due to the opon loop gane bein very
    hi
    : Thanks Robert
    thanku
    ps hows the engrish classes going
  3. Rob
    Rob Guest
    correction - crasses
  4. Robert
    Robert Guest
    Thanks for the hepl you piece of shit, sounds like you are a goverment
    worker looking at your email address, spend to much time looking for
    spelling errors then helping people KUN******
  5. Robert
    Robert Guest
    Why don`t you help people then giving them shit you arshole you KUN*******
  6. Ed-
    Ed- Guest
    Take a chill pill or two.
    damm, now you know my workplace...
    btw, ow goods ur spam filtr you little tosser?
    : Thanks for the hepl you piece of shit, sounds like you are a goverment
    : worker looking at your email address, spend to much time looking for
    : spelling errors then helping people KUN******
    : : > assignment help is expensive, but you get wat u pay 4, hey!
    : > : Keeping the circuit simple as possible for maxium output voltage,
    if a
    : > : thermocouple is conected to inputs pin 2 and pin3 is a resisor
    : > required
    : > : between input of pin 2 to output of pin 6
    : > yes
    : > for maxium output voltage or the resistor is not even required.
    : > yes
    : > : In replace of the resistor can a conection be made between input
    of
    : > pin 2 to
    : > : output of pin 6.
    : > yes
    : > : Any sensor that generates its own voltage in mili volts can that
    be
    : > fed to
    : > : the inputs of pins 2 and 3
    : > yes but
    : > : or is a negative feed back required for maxium
    : > : voltage output of pin 6
    : > yes, otherwise the o/p will saturate due to the opon loop gane bein
    very
    : > hi
    : > : Thanks Robert
    : > thanku
    : > ps hows the engrish classes going
