7406 "open collector" output characteristics
Discussion in 'Misc Electronics' started by Henry, Mar 21, 2007.
  1. Henry
    Henry Guest
    Here is a question for some old-timers:
    I need to parallel several 7406 outputs in order to sink more current.
    But each time I add one more, I also add its capacitance.
    So I need to know: what is the "output capacitance" of each 7406 open
    collector output transistor when in the "high" state?
    Thanks for any serious responses...
    Henry
  2. John Bordynuik selects "I need to parallel several 7406 outputs in order to
    sink more current."
    Why not use a transistor to sink the current?
    How much current do you need to sink?
    If you are referring to an old TTL part then the capacitance is very low.
    You could determine it from propogation delay tests or rise time from a high
    value resistive load. In any event it would probably be very low and could
    vary from component to component a bit... I doubt you will find this
    information in a datasheet.
    Regards,
    John Bordynuik
  3. Why not use a proper low side driver or SMT fets?
