738 paradox alarm system error #2 problem
Phillip Zinck
Jun 22, 2015
5
Jun 22, 2015
5
i have an alarm system . it has a 738 paradox board. the battery is new and power is stable. i am getting an error code #2 sever times through out the day. it will sound and then clear. it may be a power supply problem. looking for information on how to correct this problem. my local supplier will not provide any help to public.
has anyone had a problem like this before.
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
That's Ironic since the Paradox site Says "Personalized service".
Their website
Martin
Phillip Zinck
Jun 22, 2015
5
Jun 22, 2015
5
yep i know. they had no problem letting me buy a new sensor. and smoke alarm at different times. but can not provide any support. i know my system is old and may not be supported. still no help
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
How does your alarm work?
Do you have the code numbers and what they mean?
I had a Yale cordless alarm and zone 2 would always falsely trigger. Drove us mad.
Until I permanently evicted the spider living inside it!!
Martin
Phillip Zinck
Jun 22, 2015
5
Jun 22, 2015
5
it works fine. I have a code that tells me that I may have a power supply prob. or the charger is un able to charge battery. or batt voltage is to high. I am thinking the psu is a problem. need to try and look into that.
the spec on the ac supply say 16.5vac out and I am reading 19vac. it may be just on the edge of a limit not sure.
Kiwi
Jan 28, 2013
471
Jan 28, 2013
471
Key [2]
Power failure
Activates when inadequate AC power goes to panel OR
the power supply is unable to charge battery OR
the power supply voltage exceeds 14.9V
Is there a problem with the voltage regulator on the board?
