7 Segment LED display
Discussion in 'Electronic Design' started by Zdenko, Aug 26, 2004.
  1. Zdenko
    Zdenko Guest
    I need module with 3 7 Segment display for measuring of DC voltage 80-120V.
    Any idea?
    Best regards
    Zdenko
  2. CFoley1064
    CFoley1064 Guest
    Subject: 7 Segment LED display
    Most 3-1/2 digit panel meters are based on the Intersil 7106/7107 1-chip
    digital voltmeter IC. They provide reading of +/-200mV input, and operate on
    an isolated (battery) power supply.
    Some DPMs have a voltage divider built in to allow reading of higher voltages.
    Fortunately for you, one of these is available at All Electronics Corp (a good
    surplus outlet) as their part number PM-121. It's in stock, reads 0 to
    +/-199.9V, and is only $15.00.
    Note that these DPMs require a regulated (and preferably non-switching) +5VDC,
    and the negative of the +5V is coterminal with the - of the input voltage, so
    be careful. 120VDC is no joke.
    http://www.allelectronics.com/index.html
    If you don't like surplus, these DPMs are available at almost all full service
    electronics distributors, as well as Digi-Key, Mouser, Jameco, and all the
    other catalog houses. You'll pay quite a bit more, though.
    Good luck
    Chris
