7 segment display
Springcone710
Dec 16, 2013
4
Dec 16, 2013
4
I'm wanting to build a simple lap counter for my nephews scalextrics! I want it to be as simple as possible and if I can, I would prefer not to use adruino!
Does anyone know if it's possible to make the 7 segment display count up and cycle back to 0 with just 1 switch? If so, how?
I want to put the snap action switch in the groove on the scalextrics so that when the car passes the start/finish line, the cars leg that fits in the groove will press the switch and the 7 segment display will change!
Thanks, chris
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Fairly simply, you could connect a counter with a bcd output to a bcd to seven segment decoder, and that to a seven segment display.
The switch generates the clock signal which increments the counter. You'd probably wire up the reset line so you could push a button to reset the counter(s).
The main problem is the switch. Switches bounce, so you would need to de-bounce it so that each press generated just on clock pulse, and therefore just increments the counter by 1.
Chips you might be looking at are a 40106 (hex schmitt trigger) to be part of a circuit to debounce the switches, a 4511 BCD to 7 segment decoder/driver, and a 4510 BCD up/down counter.
The use of a BCD counter eliminates problems with values 10 to 15 which can't be displayed on a single digit. This also allows you to cascade them for 2 or more digits.
Oh, note that you need common cathode displays.
ziin
Dec 2, 2013
9
Dec 2, 2013
9
It depends on what chip you prefer to use? Two of my favorite chips are Microchip and Arduino.
If you want to use Microchip, I can give you more advice.
