7 segment display help
Discussion in 'General Electronics Discussion' started by Xrandom66X, Apr 28, 2011.
  1. Xrandom66X
    Xrandom66X
    Apr 28, 2011
    I'm putting together a seven segment display for a school project. the seven segment display (with common cathode) is the one listed here.. im hooking it up with a 7448 IC listed here. there are switches for the inputs of the chip A B C and D. the outputs go through 330 ohm resistors that finally connect to the pins of the 7 segment display.
    when i hook it all up, the numbers work fine except for a couple. 0 1,3,4,7,8, and 9 all display fine.
    on 2, the top right segment does not light up. on 5 and 6, the bottom left segments do not light up correctly. theyre not burnt out because 1 displays correctly. im looking it over to see if i accidentally shorted something together but so far can't find anything. does anyone have any ideas on what could be causing this?
  2. davenn
    davenn Moderator
    13,784
    1,934
    hi welcome to the forums :)
    please show ua the circuit you are using and mabe a good sharp photo of your project so we can see where you may have gone wrong.
    Its likely to be a wiring error
  3. nbw
    nbw
    48
    May 8, 2011
    Check you have your A, B, C, D lines tied up correctly, and also that your 7 segment pins are correct. So, segment A is the top one, then go clockwise around the digit til you get to F at top left. G is the middle.
