Jeff Dieterle
I'm using a 12vdc power supply to drive 2 octal base relays. Is there any
reason I couldn't use a simple voltage divider to pick off 6 volts to
control two solid state relays, as long as I didn't exceed the power output
of the dc supply and have enough current flow to switch the ss realys. Also
does anyone know the typical current draw for the control side of a 6-8vdc
ss relay?
ss relay?
