barathbushan
- Sep 26, 2009
- 223
- Joined
- Sep 26, 2009
- Messages
- 223
hi i am new to relays , i have this relay which i want to drive using a transistor , whose base is connected to the output of 555 timer , timed at 1 second , the emitter is grounded directly , and the relay is connected between 5v supply and the collector , with a diode connected to dissipate the counter emf of the coil , the above circuit i mentioned is not working , i hear clicks of the relay but still is not working , i changed the relay , it was still of no use .
what could be the problem , can it be the 5 volts supplied to a 6v coil ??
also please tell me the maximum and minimum values can a relay rated at 6v can take .
Thanks !!
Thanks !!
