68HC11 port B
Discussion in 'Electronic Design' started by john, Jan 24, 2006.
  1. john
    john Guest
    I am having problems with the port B. Its an output port and I am
    writing the whole port. My code is as follows
    ORG 2000
    LDAA $# FF
    STAA $1004
    Now, if I write 00 hex or FF to theport. The port is always floating.
    I tried pull ups and pull downs but no difference. Please advice.
    Regards
    John
  2. Tim Wescott
    Tim Wescott Guest
    The 68HC11 that I worked with allowed you to program the direction of
    the port -- with the direction bit flipped one way (0 IIRC) the port was
    a high-impedance input, and with the direction bit flipped the other the
    port was an output. Most of those ports could also be configured for
    open-drain output, if you so desired.
  3. James Beck
    James Beck Guest
    Not PORTB.
  4. Rich Grise
    Rich Grise Guest
    Take a look at the data sheet, and look for the "Data Direction Register",
    or DDR. You'll need to configure the port as "output".
    In case you're trying to do this without a data sheet, here's one:
    http://www.freescale.com/files/microcontrollers/doc/data_sheet/M68HC11E.pdf
    Also, are you trying to run it in expanded or special test modes?
    Good Luck!
    Rich
  5. James Beck
    James Beck Guest
    PORTB is not bidirectional and has no DDR.
  6. Rich Grise
    Rich Grise Guest
    So, the OP is Simply Out of Luck. )-;
    Rich
  7. James Beck
    James Beck Guest
    Well, yes and no.
    He wants to treat it like an output, so I guess it is fortunate that
    PORTB is an output only port, but if it is truly "floating" then he is
    screwed. ;)
  8. bruce varley
    bruce varley Guest
    And in expanded mode it outputs low order address bits. Could that be your
    problem?
