6150rf capacity
L
LJP602
I am a diy alarm installer and have a vista 20p and a 6150rf in the system.
Is there a difference between different 6150rf keypads relative to the
capacity of wireless transmitters. I see some of them say they have the
capacity for 16 transmitters and others that talk about 8. Is there a way of
telling the capacity visually?
Larry
JoeRaisin
Larry
There are three levels of 5881 RF Receivers.
The 'L' which has 8 zone capacity
The 'M' which has 16 zone capacity
The 'H' whose capacity is determined by the limit of the panel used.
RF Keypads incorporate the 'M' receiver (16 zones) along with a built in
transmitter which means you could use a BDV type remote without
installing a separate 5800TM which you would need if you used one of the
stand alone receivers.
One important note, if you want to use a wireless keypad (which I would
discourage as their performance has been disappointing in my experience)
neither of these items/combinations work and you will need a 5883
receiver/transmitter.
L
LJP602
transmitter which means you could use a BDV type remote without installing
a separate 5800TM which you would need if you used one of the stand alone
receivers.
Thanks for the help Joe, I have read of several people not experiencing good
things with the wireless keypad so I decided to stay away from it. 16 zones
should be plenty for my needs.
LP
