P
PDRUNEN
Hi Group,
Consider the 1VA 120 to 10 V transformer designed for 60Hz. Can I use this as
a audio transformer for frequency range of 60Hz to 10KHz ?
I would be stepping up the voltage so the signal would be on the 10V side of
the transformer.
If my sig generator can output 10V at 60Hz with an output impedance of 600
ohms, and I step this up to 100V on the other side of this transformer, would
the output impedance be also stepped up by a factor of 10 or 10 squared, or
other?
I would expect to be able to measure it by first measuring the unloaded output
then loading down this output until the measurement was 1/2 of the unloaded
measurement, is this true?
Another unrelated question, if I DC recify the AC main to full-wave and drive a
light bulb, the voltage is now unfiltered DC. Consider the 100 watt light
bulb. Would the life of the bulb be reduced now that the current flows one way
into the bulb?
Tnx de pdrunen.
the transformer.
other?
into the bulb?
Tnx de pdrunen.
