6 Volts - 7 volts
Discussion in 'General Electronics Discussion' started by raymondht, Apr 26, 2010.
  1. raymondht
    raymondht
    6
    Apr 26, 2010
    Hello, just want to ask if we can increase 6V to 7.2V by just adding somthing..:D
  2. (*steve*)
    25,482
    2,830
    another battery?
  3. Mitchekj
    Mitchekj
    288
    Jan 24, 2010
    Beat me... I was going to say "Oh, about 1.2V."
  4. davenn
    davenn Moderator
    13,798
    1,939
    hahaha good responses steve and Mitchekj :D
    but in all seriousness, raymondht, we need a bit more info from you of the circuit involved
    If for example the cct in question was being supplied via a 7806 voltage regulator, the
    input to the regulator is likely to be ~ 10 - 12V and yes with a couple of resistors
    you can jack up the output of the regulator a bit ( up to a couple of volts or so)
    is being supplied from say a 6V battery then not much you could do and still keep the
    current ratings.
    There are voltage multiplier ccts, and I have used voltage doublers, but current supplied
    is the big sacrifice
    cheers
    VK2TDN
  5. ElectronWorks
    ElectronWorks
    28
    Aug 20, 2009
    or failing that, try Googling 'boost converter' These circuits use the back emf of an inductor to boost the voltage. They are used in pretty much all portable devices from laptops to mobile phones
  6. raymondht
    raymondht
    6
    Apr 26, 2010
    its a battery lead acid battery, its only 6V, but my device needs 7.2v...
  7. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    What exactly is your device? How much current does it need?
    ---55p
  8. raymondht
    raymondht
    6
    Apr 26, 2010
    Its a hand held video camera. JVC Everio
  9. chejian6
    chejian6
    Apr 29, 2010
    a boost converter, a charge pump, a battery...
  10. davenn
    davenn Moderator
    13,798
    1,939
    ok forget the 6V battery, get a 12V sealed lead acid or similar battery and use a voltage regulator to produce the required voltage needed for the video cam there are a number of good hi current adjustible V-regs out there that would be able to handle the current required by your camera eg ... my favourite the LM338 5 Amp TO-3 casing
    I have used for so many projects over the years
    with a 6V battery and using any sort of boost converter is going to run into probs
    as the battery drops in voltage out as it discharges.
    with a 12V battery you are going to have several volts of discharge "headroom" without
    affecting the output of the regulator.
    cheers
    VK2TDN
  11. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    Using a linear regulator to go from 12V to 7.2V, you are wasting 40% of power. If the 12V was coming from a wall outlet, that would not be a big deal. But if it is coming from a battery that you need to lug around, it does become a big deal. A 12V to 7.2V step down DC-DC converter, or a 6V to 7.2V step up DC-DC converter is more appropriate (in that order).
    But for some people, a linear regulator is the extent of their capabilities.
    ---55p
  12. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    Let me repeat the question: How much current does it need?
    ---55p
  13. raymondht
    raymondht
    6
    Apr 26, 2010
    problem is 12V lead acid is huge!... its like 5in wide 4in ht and 2in thick and its heavy While 6V half of it.
  14. (*steve*)
    25,482
    2,830
    Lead acid batteries come in all shapes and sizes. It's almost certain that you can get a 12V lead acid battery that is very close to the size, shape, and weight of the 6V one.
  15. raymondht
    raymondht
    6
    Apr 26, 2010
    oh isee ok i'll check if theairs available lead acid 12 v small size... by the way what type of charger I cam use... Can I use my regular charger?
  16. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    Only if it is a lead acid battery charger.
    ---55p
  17. (*steve*)
    25,482
    2,830
    *and* suited to the Ah rating of your battery.
  18. raymondht
    raymondht
    6
    Apr 26, 2010
    ok it means much Hugher ah right? ill gor look for one.
  19. (*steve*)
    25,482
    2,830
    No, not necessarily higher, just appropriate.
    If it's a 1.3Ah battery, then you need a charger that can charge this capacity. Say 1 to 7 Ah. A charger suited for 20 to 200 Ah would NOT be appropriate.
