Rich said:
Speaking of aluminum heatsinks, is there a measurable difference
in thermal resistance (HS-to-ambient) between plain aluminum and
black-anodized aluminum, all other things being equal?
There is a radiant component of heat sink performance, but
it goes up at the 4th power of absolute temperature
difference between the sink and its visible surroundings,
and in proportion to its emissivity. So an emissivity near
zero (shiny aluminum) pretty well eliminates this component.
But even if the emissivity approaches 1, it still takes a
quite hot sink surface to make this effect very significant.
So if you intend to operate the sink in still air at
something like 125 C in a 25 C environment, you might get
your money's worth out of the black dye job. If you have
forced convection or can spend that few percent on a
slightly larger heat sink, you will probably do better with
that.
Also, if the sink is made of parallel fins, almost all that
radiated energy is just passed back and forth between
adjacent fins. So it only helps on parts of the sink that
"see" the cooler environment.
