6 pole 2 position toggle
Discussion in 'Electronic Design' started by arthur, Nov 3, 2005.
  1. arthur
    arthur Guest
    I'm need to find a 6 pole 2 position toggle switch for a telecom
    application I'm working on. The only ones I've found are located
    overseas.
    Any ideas on where to get one?
  2. arthur wrote...
    Time to use some small relays.
  3. which "overseas" are you refering too?
    martin
  4. Guest
    Digi-Key has several 3PDT and 4PDT toggle switches - can you
    mechanically gang two 3PDT switches? Or, if you're going to play the
    mechanical-gang game, stack up a bunch of microswitches.
    They have a 6PDT pushbutton EG1544-ND but it's momentary.
    Look at page 1348 of their latest catalog (T053). Several of the rotary
    switches will do it, but will cost you about $20 each.
    Matt Roberds
  5. w2aew
    w2aew Guest
