5v - 2A power supply causing damage
Discussion in 'Power Electronics' started by Fractus, Dec 31, 2020.
  1. Harald Kapp
    10,833
    2,442
    What is the voltage at the micro USB connector with no load connected? Sometimes the output voltage of a not well designed power supply may be much higher than the nominal value when no load is connected. If you then connect this supply to a load, the output voltage will drop to the nominal value but the initial value being too hihj may already have caused havoc.
  2. Fractus
    Fractus
    18
    Dec 31, 2020
    5.37v
  3. Harald Kapp
    10,833
    2,442
    That is reasonable and no cause for concern.
  4. Fractus
    Fractus
    18
    Dec 31, 2020
    Ok, but why it ruined my JBL Go and powerbank !!!
  5. Martaine2005
    Martaine2005
    3,102
    851
    May 12, 2015
    Can you please answer post #19.
    The answer may be there.
    Martin
  6. Fractus
    Fractus
    18
    Dec 31, 2020
    White is instead of black (negative)
  7. Martaine2005
    Martaine2005
    3,102
    851
    May 12, 2015
    Yes, I understand that.
    But did you connect ‘BLACK’ first as negative, like your first drawing?.
    Martin
  8. Fractus
    Fractus
    18
    Dec 31, 2020
    Yes I did as per my photo post #15
  9. Martaine2005
    Martaine2005
    3,102
    851
    May 12, 2015
    WHITE is Data - (negative)
    BLACK is signal - (negative)
    Did you connect the devices when you had the WHITE as - (negative)?
    Martin
  10. Harald Kapp
    10,833
    2,442
    It is getting confusing: the image in post #15 shows a white wire, not a black one.
    @Fractus : help us sort this out:
    • How many wires are in that cable from the power supply?
    • What are the colors of these cables?
    • How did you connect the cables to the micro USB plug?
    • If there are more than 2 wires in the cable, have you swapped any of them?
    • Which measurements have you made and what were the results?
    Please give us a comprehensive and concise explanation. It is hard to follow along when information comes piecewise and partly contradictory.
    Martaine2005 likes this.
  11. Fractus
    Fractus
    18
    Dec 31, 2020
    1. There are two wires from the power supply - see post #15 (white wire replaces black I presume......please note I'm new to electronics)
    2. The only colours from power supply are red and white.
    3. Connection of cable to micro USB see post #15.
    4. Cannot understand your comment on measurements !!!
    Thanks!!!
  12. Fractus
    Fractus
    18
    Dec 31, 2020
    Yes
