59 ohm resistor
Discussion in 'General Electronics Discussion' started by Jon Germany, Feb 14, 2016.
  1. Jon Germany
    Jon Germany
    Feb 14, 2016
    I am trying to repair a alarm system i own but i need to replace a resister thats gone off value due to getting hot. Its a 59 ohm - 1 watt - 5%. I have looked everywhere on the net and found nothing better than 250ma in 59 ohm's. Can anyone help with either a 1 or 2w resister please
    cheers
    Jon
  2. davenn
    davenn Moderator
    13,801
    1,941
  3. Jon Germany
    Jon Germany
    Feb 14, 2016
    Thanks for the reply Dave but the minimum order quantity of 2500 is a bit more than i need.
  4. Externet
    Externet
    759
    165
    Aug 24, 2009
    Welcome.
    Use two 120Ω paralleled, or any values that sum your needs in series. Discarded switching power supplies or other equipment may have suitable values. Canibalize.
  5. 73's de Edd
    73's de Edd
    3,070
    1,299
    Aug 21, 2015
    Jon . . . . . .
    How in the world could a common alarm circuit really,really,really require a "59" ohm value of resistor yet be so liberal as to spec it at %5 tolerance?
    Is that value printed on the part or using color bands ?
    Those bands could shift coloration when being subjected to heat, particularly near the central hotter area.
    Orrrrrrrr . . .could a purchase agent got "such a deal, already" on 5000 "59" ohm resistors., that was what got bought.
    A more commonly available 56 or 62 ohm should fall just within your tolerance spec.
    If I actually have need for such an odd value resistor and actually being in a critical resistance function.
    I get a just higher resistance value of a very liberal wattage above the subscribed wattage and then parallel shunt it with a higher and lower wattage
    resistor to trim right to that desired resistance.
    In this case getting a 62 ohms value in a common 7 watt metal film resistor and being shunted with a 1/2 watt metal 1200 ohm unit will yield ~ 58.954 ohms,
    with compensation of tolerance variations needing to be considered.
    With that "cushy" 7 1/2 watts power spec . . . . . its then running at "cool city".
    73's de Edd
    Aside:
    L o o o o n g time . . . no see no "external-net" . . . que pasa ?
  6. Externet
    Externet
    759
    165
    Aug 24, 2009
    Que pasaaaa Edddddd...:)
  7. davenn
    davenn Moderator
    13,801
    1,941
    you sure .... many buy in singles or small Q's from digikey
    but Externet's way is the best way to go
