5804 arm/disarm assign code question
Discussion in 'Security Alarms' started by Crash Gordon®, Feb 4, 2005.
  1. This drives me crazy all the time.
    I have 5804 on Vista 15P.
    Loop 1= Fire
    Loop 2= Off/Disarm
    Loop 3= Arm
    Loop 4= Panic
    I can't remember how to add the code for the Arm/Disarm Buttons to work. I assigned User 31 = a code, but when I add the attributes...I dunno what the "Value" is supposed to be. Or is the "value" supposed to be the user code????
    Their instruction books are getting better!...but I still can't find what I'm doing wrong. The user 31 code does work if I arm/disarm from manually from the keypad.
    tnx
    Rob
  2. A.J.
    A.J. Guest
    I am not sure if the 5804 needs a user code to work with a 15P.
    Loop 1= Fire
    Loop 2= Off/Disarm
    Loop 3= Arm
    Loop 4= Panic
    code????
    from the keypad.
    tnx
    Rob
  3. It does, but only for the arm/disarm - the panics work without user code.
  4. A.J.
    A.J. Guest
    If it does, you would see the option on a Alpha keypad when you are
    programming the user number.
    Something like [RF Button]
  5. Yah...I got it...just a brain fart. I'd programmed it correctly, but when I tested it I just didn't hold down the ARM button long enough...sheesh what a maroon! - wasted an hour with that.
  6. Mark Leuck
    Mark Leuck Guest
    You would if it was while changing user codes in a Vista-40 and up but it
    doesn't show on a Vista-15P/20P even tho you do have to do it
  7. G. Morgan
    G. Morgan Guest
    Subject: Re: 5804 arm/disarm assign code question - disregard
    Newsgroup: alt.security.alarms
    hmmmmmmmmm.............
  8. hey it was late...my brain was fried, probably by some Belgium RFI muzzlement...what can I tell ya ! :)
    anyway...it's alll programmed and tested ready to install tomorrow - just pop it in.
