Raven Luni
- Oct 15, 2011
- 798
- Joined
- Oct 15, 2011
- Messages
- 798
Greetings,
I've built most of the circuit for my M.U.N.T.E.R. project (diagram here: http://www.stonewolfsoft.co.uk/temp/munter01.gif )
I've ran into a bit of a problem though. The presence of the 2nd 555 for resetting the counter when it reaches 8 seems to completely bugger the master reset circuit.
First of all, there are a couple of minor differences in the way I've built it than in the diagram. Everything up to the 1st half of the programmer circuit has been built (the 4 ICs on the right havent been added yet). The 193 on the left is actually a 74HCT193 (all I could get) and instead of the Q8 pin going back to the reset, the output from the 555 is connected there instead (and neither of the 100nF capacitors to ground are there either).
What happens is that the master reset wont even trigger (and neither does the counter reset for that matter). If I take the second 555 out of the socket, the master reset works fine. The only other thing of note is that the routput to the reset pin is also connected to an LED via a 330 resistor.
All ICs except for the master reset 555 have 100nF bypass capacitors.
Almost forgot, the timing RC values for the 555 and 556 ICs in the programmer and audio interface are all 10K and 100nF and not the ones in the diagram.
