A
asdf
I have built 555 oscilator, and I need it to oscilate at about 50-100 Hz
(Hertz, not kilo-Hertz) range. I am just a beginner.
It should mimic my car engine ignition since I would like to use it as a
test input for a tachometer I am building. So, 50-100 Hz range corresponds
to 3000-6000 RPM of the engine.
R1 is 100 k trim pot (changeable resistance) and C is 0,22 uf. R2 is 1k.
Scheme is classic, with only one capacitor.
According to the calculations, this should give me 65 Hz to over 500 Hz
range which would correpsond to the
But, when I measure it, my DMM says frequency is in kHz range! When I try my
DMM on the power outlet, it says correctly 50 Hz, when I connect it to my
computer and use some program to generate freqeuncy, it shows perfect
results.
Could it be that the duty cycle at about 85-90% tricks my DMM into false
reading? All other tests I have made with md DMM were with 50% duty cycle.
Is the missing C1 from the Cont pin a problem (I do not use it according the
the scheme I had).
What am I doing wrong?
results.
the scheme I had).
