52 inch magnavox tv showing the same channels
Discussion in 'Electronic Repair' started by [email protected], Jun 8, 2007.
  1. Guest
    My television keeps showing the same channel. It will not show any of
    the cable channels. The tv is showing the same channel on 5 tv channels
  2. Meat Plow
    Meat Plow Guest
    Check the tuner.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    #8 AUK Hate Machine Cog
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. Guest
    When I program the tv channels automatically, the tv will not pick up
    the cable channels. The cable works. I tried it on another tv. It use
    to work on this tv. I purchase a universal remote and I believe it
    unprogrammed the tv. I can still play my xbox and watch dvd's. I just
    cannot watch cable.
  4. Guest
    Is there a factor reset option on magnavox rear projection tv's?
  5. Meat Plow
    Meat Plow Guest
    Maybe in the service man mode. You try unplugging the set for an hour or
    so? (not that this will fix your problem)
    COOSN-266-06-25794
  6. Bob Shuman
    Bob Shuman Guest
    Check to make sure the TV is not in the "antenna" mode and set to cable
    before trying to program it. Also make sure the cable feed and the patch
    cable from the wall jack are both good. (Maybe that is what you meant by
    knowing the cable is good.)
  7. R!
    R! Guest
    wrote in @n4g2000hsb.googlegroups.com:
    The tuner is probably bad, usually gets 1 channel repeating on VHF (2-6)
    but the actual channel is (cable 22 or 23)nothing on the rest.
    This used to be quite common when I serviced sets about 10 years ago.
    If the set is that old you may want to use a VCR on the video imputs and
    use it to change channels.
    Those tunuers are plated through hole or surface mount technology, a
    little hard for the DIY crowd.
    Give it some thought analogue will be dead in early 2009 here in the
    USA.
    R!!
