50H82 Toshiba noisy lines across pic.
Discussion in 'Electronic Repair' started by Jason D., Mar 14, 2006.
  1. Jason D.
    Jason D. Guest
    Did the capacitors replacement in the hyper module got the color back
    except I have noise horizontal lines across image on whole screen. It
    goes away gradually as TV runs for several minutes after cold start
    up.
    Seen this before?
    Cheers, Wizard
  2. kip
    kip Guest
    Jason How Many Caps Did You Replace On The Board ?
    kip
  3. Jason D.
    Jason D. Guest
    Kip, all of them, made sure to use computer grade caps. Including 11
    10uF 16V caps.
    Cheers, Wizard
  4. kip
    kip Guest
    Ok Jason ...I have done many and now always change all of them.
    Check the socket were the Module plugs in resolder both the
    socket and plug sections just to be safe.
    What I did first was to photograph the Module so ,as when installing them
    I didn't put any in backwards and good job I did because one time
    I put one in backwards,best double check your work.
    kip
