R
Ron(UK)
No, I don't see any coil or solenoid as far as I could tell. The tiny
motor has a metal cap on one end integrated so I don't know what's
inside. It's a Crouzet motor TMX 88900048 A 32591. I already tried to
research the specifications of the motor but hit a dead end before.
If there`s no solenoid, then it`s most probably that the timer itself is
faulty. There was a common problem with some Hoover machines here (UK)
where the timer would skip through the rinse cycle in minutes. The cause
was the geneva drive in the timer (Crouzet) jamming.
Has the fault been apparent on the machine always since it was first
used on 60 hz, or has it developed recently?
Ron(UK)
