5 Volt Supply
Discussion in 'Electronic Basics' started by slhawks, Apr 23, 2005.
  1. slhawks
    slhawks Guest
    I am building a radio control remote for a camera requiring a 5Volt 13 m/a
    supply
    and using 4 x AAA
    Are any smaller batteries available to keep the size and weight down
    Any Help appreciated
    Many Thanks
  2. Tom Biasi
    Tom Biasi Guest
    You could use button cells.
  3. slhawks
    slhawks Guest
    I should have said 4 x AAA rechagable Nimhs
  4. mike
    mike Guest
    Ok, then use rechargeable button cells...
    but seriously...
    Lithium is the way to go for light. If you can make the system go on
    4V, you may get by with one lithium cell.
    If you've got a radio receiver, why not just steal power from that?
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Wanted 12" LCD for Compaq Armada 7770MT.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
  5. I bought 50 LR-44 button cells (alkalines) on Ebay for about $6
    including shipping. They came packed in tear-off blister packs. These
    are the ones used for laser pointers and LED flashlights. They will
    handle 13 mA for a few hours. But they're only a dime apiece so you
    just throw them away and put a few more in. Four of them will give you
    about 6V, so you can put a 1N4002 rectifier diode in series with one
    lead to drop about .8V to give about 5 or so volts.
  6. slhawks
    slhawks Guest
    With the lower the volts and m/a the longer life I am trying to compromise
    between this and working range
    Many thanks for your help
    Syd
