5 volt supply straight from 240v AC mains
Discussion in 'Misc Electronics' started by techie_alison, Jul 13, 2006.
  1. Hi,
    Please may I ask what the arrangement is when you see a single LED powered
    straight off of a mains power supply without any transformers or switch mode
    circuitry? In other words, totally uninsulated or regulated.
    I have an old computer with an external hard disk which needs about 30
    seconds to spin-up before the computer. With a small timing circuit, 555,
    or using a PIC even (have dozens) after a set time a relay would be set,
    thus powering on the computer. A 7805 could be introduced to take into
    account the voltage swing. Half wave rectification could result in 120v
    too.
    This doesn't need to be insulated from the outside world, safety is not a
    concern, just that roughly 5v should be available for the small circuit and
    the 3amp relay.
    Any ideas?? Just interested to hear of how this is done. Or would it be
    easier to just buy a small tordial TX and make the box a bit bigger?
    Aly
  2. Tom Lucas
    Tom Lucas Guest
    I think you'll find that that is a neon lamp and not an LED. LED's
    connected directly across the mains will give light in the form of fire.
    Why not buy a 5V supply to run the electonics off rather than mess with
    mains yourself?
    SAFETY IS THE PRIMARY CONCERN! Mains is not something to be fooled with
    or it WILL kill you. Insulate everything or when you (or somebody else)
    is not at full concentration you will touch something and die. There
    should be fuses and other protection in the circuit as well. This is why
    you should seriously think about buying a supply and letting someone
    else handle the high voltage design - and the legal concerns that go
    with it.
    If it were me then I would use 5V from the Hard drives supply to trigger
    a PIC (but a 555 or an RC circuit would be just as good) to control the
    PC's power switch. If the PC has an ATX supply, then great because you
    can stay low voltage and use a simple relay to replace the PC power
    switch (remembering that only a pulse is required to simulate a buton
    press). If the PC supply is AT then the power switch is mains and you
    could use a mains relay switched by 5V but you need to be sure that the
    terminals are properly insulated on the mains side.
    Seriously, your tone doesn't sound like you are giving mains electricity
    the respect it needs. I know enough people who have died from electric
    shocks and each time it was because they thought safety wasn't a
    concern. Be careful.
  3. Peter
    Peter Guest
    Half wave rectification would NOT result in 120V and a 7805 can't drop
    anywhere near that much voltage. If you don't know this then it would be a
    very bad idea for you to make any live circuit. I recommend that you use a
    wall wart for your 5V.
    Having said that, a mains rated capacitor in series can be used as a sort of
    voltage dropper followed by a rectifier to get low voltage. I actually found
    a circuit like this in a Russian battery charger from the 60s. Yikes! You
    get small size at the expense of safety and I don't think that its
    worthwhile.
    Peter
  4. Typically a series capacitor is used with a capacitive reactance
    sufficiently large at the mains frequency to limit the current to a
    desired value. Due to harmonics and other high frequency noise usually
    present on the mains, the capacitor reactance at these high
    frequencies are quite low, thus quite large peak currents could flow,
    thus, it is a good idea to also include a series resistor.
    These kind of circuits only makes sense with very low current demand,
    since at higher currents, the capacitors become quite large.
    In order to minimise the load current and hence the required capacitor
    size, it would be a good idea to use a relay with a large coil voltage
    (and hence low coil current) driven by a high voltage open collector
    output or a separate high voltage transistor.
    Paul
  5. Mmmm, hi Paul
    I think I'll stick with a small toroidal. Much more in line with what I've
    done before, just had seen the LED concept out there before and wondered how
    applicable it was.
    Aly
  6. I still have a US made battery charger from the 60s that is composed
    of:
    * 2 safety interlock switches to disconnect both sides of the line when
    the lid is opened.
    * a rectifier.
    * a 4 watt night light bulb.
    Marc
  7. Jim Stewart
    Jim Stewart Guest
    Yeah. Sounds like a good idea.
    In my youth I had an early model airplane R/C
    set. The battery pack was charged with an on-
    line charger.
    I can painfully remember touching the wrong part
    and doing the chicken walk.
  8. Go to Microchip's website and look at the AP note TB008 "Transformerless
    Power Supply". The example is for 115 VAC, but the concept is the same.
    Don
  9. John Perry
    John Perry Guest
    Tom Lucas wrote:
    Actually, the neon lamp will explode :). Unless you're careful to get
    a neon _indicator_, which will have the necessary current limiting
    resistor built into the package.
    John Perry
  10. Neil
    Neil Guest
    Actually Some power strips use and LED. And a large resistor.
  11. default
    default Guest
    Piece of cake if you know the current consumption of your circuit. I
    run LED's and small circuits directly from the 120 VAC 60 HZ mains all
    the time.
    Use a capacitor to drop the voltage. - no heat and no energy wasted.
    You take your circuit - measure the current and voltage it needs.
    Subtract the voltage from the mains supply voltage and calculate a
    "dropping capacitor" for the voltage you want to drop with the current
    you need.. Use the formula for capacitive reactance.
    Put the cap and a 100 ohm 1/2 W resistor in series with one side of
    the mains - the resistor is to limit inrush current as the cap charges
    and works as a fuse if the cap shorts. That goes to your four diode
    full wave bridge rectifier.
    Here I use ~.47 ufd/250 Volt caps for lighting a LED or two or three
    in series from the 120/60 mains
    If you are just interested in using an LED on the mains supply - you
    can just bypass the LED with a small diode to keep the reverse voltage
    from getting over .6 volts instead of using a rectifier or use back to
    back LED's and light two with no rectifier.
    The cap should be a non-polar type with an AC rating for the mains
    voltage or 3X the DC rating.
    Don't use the circuit with no load - the output voltage will be high.
    When powering circuits you have to take into consideration your load -
    if you're driving a relay, for instance, the current will be much
    higher when the relay is energized. So in addition to solving the
    capacitive reactance for the relay current + circuit, you also have to
    give it some means to prevent voltage overshoot when the relay is not
    energized - a simple shunt regulator with a single 1 watt zener may be
    all you need -
    I posted the data from the Siemens 1990 Optoelectronics data book
    "Operating LEDs on AC Power, Appnote 6 " on
    alt.binaries.schematics.electronic a couple of months ago
    Another way to steal a little bit of power that may come in handy for
    your disc spin up timing - a current transformer. Just add a few
    turns of wire to a transformer with an open core (like a toroid or
    side by side bobbin transformer) and put the load on the low voltage
    windings - A trick we frequently use to turn on solid state relays
    when an X-ray machine or other dangerous piece of equipment is running
    - to sound horns or work warning lights. A little trial and error
    involved - but that ties the output to a load - whenever the load is
    drawing current the output is there.
  12. Byron A Jeff
    Byron A Jeff Guest
    First off it's a dangerous one. A non isolated, non stepped down, non regulated
    circuit connected to 240V is a terrible accident waiting to happen.
    Why? Any old wall wart you have laying around can safely bring the voltage
    down to a safe level.
    There's no apparent reason as to why you wouldn't want to take the much
    more safer route.
    Unless you have a cost concern here, there's no justification for throwing
    safety out the window. None whatsoever.
    If you are determined, Microchip has a Technical Brief for a transformerless
    power supply. You can find it here:
    http://ww1.microchip.com/downloads/en/AppNotes/91008b.pdf
    This is dangerous. The brief says that it's dangerous. I'm telling you that
    this is dangerous and that you shouldn't do it. It's a safety hazard and a
    fire hazard and there's no good justification.
    My suggestion: DON'T DO IT!
    'nuff said.
    BAJ
  13. Byron A Jeff
    Byron A Jeff Guest
    Absolutely. BTW you can connect an LED directly to the mains under a
    couple of conditions:
    1) You use sufficient current limiting.
    2) You make sure to wire your LED with another diode (which can be another LED)
    in antiparallel configuration. This limits the reverse voltage for each of the
    diodes.
    I rigged up a cheap 120VAC motion sensor by tying the LED of an optoisolator
    directly to the 120V light fixture of motion sensing lights. I used a 10K
    2W resistor and a reverse LED as a local indicator. The optoisolator converted
    the dangerous 120VAC into a safe optoisolated 12VDC.
    BTW the current limiting applies to neon bulbs also.
    BAJ
  14. Mark Fortune
    Mark Fortune Guest
    If memory serves, I have seen this done once with an LED using a pair of
    resistors as a voltage divider - it might have even just been the one
    resistor. Personally I think it was cheap workmanship though. This will
    work with an LED, although it will flicker as it's only illuminated for
    less than half the time, I think it can work with only one resistor but
    only when you know the resistance of the device it is powering.
    For hard disks this is a non option - as thier resistance varies wildly
    as it spins up, settles, and does all its internals stuff, and the
    resistors would have to be big mothers as hard disks draw a hefty
    current. No no no no no
    forgive me if I seem a little dense here... but if it's an external hard
    disk, does it not have its own regulated power supply? could this not be
    utilised in some fashion? but what sort of interface is it? ide, scsi,
    parallel? that might give us some clues as to what would be a good solution.
    safety is always a concern.
    I need a bit more information on your set up really, but I can envisage
    two possible scenarios:
    scenario 1) you have a true external hard disk, in an external hard disk
    caddy with all the wiring and gubbins and some sort of parallel
    interface whotnot. The drive is powered independantly of the computer.
    If this is the case I would utilise the regulated 5v line powering the
    hard disk
    however, I think scenario 2 is more likely:
    scenario 2) You have a hard disk that is external of the computer -
    connected via an IDE lead and the computers power supply. You need the
    hard disk to power up before the computer - although I dont know why at
    this stage, but i'll pretend for now there is good reason for it. If
    this is the case, you NEED a good regulated power supply for the drive,
    and not just the 5v line if its a 3.5" drive - 12v will be required as
    well or it wont spin up. 2.5" disks generally only require the 5v line.
    Your best bet is a regulated 5v/12v power supply - which should be
    fairly simple to construct. then simply run the timer circuit off that
    supply.
  15. Check out this:
    Step-down rectifier makes a simple dc power supply
    http://www.edn.com/archives/1998/040998/08df_06.htm
    Link was picked from http://www.epanorama.net/
  16. You could use a 12K (12000 ohm) limiting resistor in series the the LED to
    limit the average current of the LED to around 20ma. The 12K resistor will
    need to be at least a 5 watt unit and will get pretty warm during operation.
    You will also need a bypass diode hooked across the LED with the anode of
    this diode to cathode of the LED and vise-versa to limit the reverse voltage
    of the LED.
    The avoid the loss of power and subsequent heat generated by the resistor
    you can use a 0.22 uf capacitor in place of the resistor. Make sure the
    voltage rating of the capacitor is at least around twice the peak value of
    the AC or around 600 volts. It must be a non-polar capacitor (most
    electrolytics are polar).
    C is calculate from the following formula: C = 1/2*Pi*f*Xc
    this formula is an algebraic variation of the capacitive reactance formula
    We use to use this technique to limit current for indicator lights in 440
    volt power distribution switchboards.
    NOTE: You can still get shocked by this arrangement if either or both of the
    diodes open. 20ma of current across your heart is enough to kill you. Don't
    even try this if your not familiar with the proper electrical safety
    measures.
    The safest technique, by far, is to use a small, step-down transformer
    because of the increased level of isolation it offers.
    Dorian
  17. thinh
    thinh Guest
    Tom Lucas viết :
  18. default
    default Guest
    There's no question that a wall wart is safer than a non-isolated
    supply, for some applications. But this vociferous reaction about how
    dangerous it is - is just not justified.
    Many of us learned on vacuum tubes where the plate supply was an order
    of magnitude more lethal than any mains voltage one might encounter.
    Ever see the inside of a 100 KW transmitter power supply? Build a
    Tesla or Induction coil? Rail Gun? Coil Gun? Vacuum tube amp or
    transmitter? Line regulator? Repair a TV set? Power Factor
    correction circuit? etc..
    When all you need is a small indicator or circuit it makes sense to
    use a cap to drop voltage - more efficient than a wall wart, takes up
    less space, less cost, lighter, no waste heat to speak of. The
    enclosure provides the shock protection.
    For tinkering with circuits on a breadboard - or just learning
    electronics, I'd agree it is too dangerous. But the op mentions it
    doesn't need to be isolated, so he probably already thought of using a
    wall wart.
  19. IMHO, 99% of the time this topic comes up, it falls into the category
    of "if you have to ask, don't use it". The 1% are mostly sensible
    reliability and regulatory compliance concerns from people who do know
    fairly well what they are doing.
    Best regards,
    Spehro Pefhany
  20. At least in Europe, all tube televisions and many tube radios had a
    universal (AC/DC) power supply, with a half wave rectifier generating
    the B+ line about 200-250 V, thus there was only a rectifier between
    the other mains plug terminal to the B+, while the other mains plug
    terminal was directly connected to the metallic chassis. Depending on
    the way the mains plug is inserted into the wall socket, you either
    have the Neutral in the chassis or the full 220 Vac Live in the
    chassis. Also the tube heaters were in series and across the Live and
    Neutral, possibly with a VDR in series to limit the inrush current.
    When working with such equipment I have used two main principles,
    before starting to work, I _always_ checked the mains plug orientation
    by measuring the metallic chassis voltage. When working with active
    equipment, I put my left hand in the pocket and only work with my
    right hand inside the equipment. This avoids the risk of having the
    current flow through your heart. If you get a muscular cramp in your
    right hand due to an electric shock, you still have the left hand
    operational to cut the power.
    Regarding low power devices powered by a series capacitor, I would
    suggest using capacitors intended for mains filters.
    Instead of a single capacitor on the live side, put two in series,
    each connecting one side to the respective mains plug terminal, while
    the other terminal of each capacitor goes to the load (rectifier
    etc.). In this configuration, the small signal circuit is floating
    around 110 Vac. If you accidentally touch the small signal circuit,
    there is still the other capacitor in series between the mains voltage
    and you, limiting the current through your body. If you want to limit
    the worst case current to 30 mA, the normal circuit current
    consumption must be below 10-15 mA, since in normal operation, there
    are two capacitors in series.
    Paul
