5 Pins Micro USB Pin Out
Discussion in 'General Electronics Discussion' started by g88, Jan 13, 2014.
  1. g88
    g88
    3
    Jan 13, 2014
    Hi i am new and new help here.
    I bought these Micro USB connector from ebay thiking to DIY replacing my phone charging/data cord connector :eek: but upon i received the connector i found i am lost with the pin out :(
    Now my splice cable i have some with red, black, green and white wire in it (i presume red and black is +ve and -ve) how about the rest of 2 wire ?
    Can i also use broken house USB cable and 'transform' it into a charging cable ?
    Please help me out.
  2. (*steve*)
    25,501
    2,841
    Get a working cable with the same connectors on the end. Use a multimeter to see which pin is connected to which pin. Then use the multimeter to determine which wire is connected to which pin on the splice cable you have. Then use the multimeter again to make sure you connect each wire to the correct connection on the other plug.
  3. g88
    g88
    3
    Jan 13, 2014
    Sorry i do not have a multimeter, even there is the pin is so small + i have no idea how to use the multimeter to test so on :eek:
  4. BobK
    7,682
    1,688
  5. g88
    g88
    3
    Jan 13, 2014
    Thanks for the link, i just want to know from the image i posted which point is for which pin in the connector ?
  6. BobK
    7,682
    1,688
    The article I linked to tells you exactly that.
