Hello,
I have a LG HT356SD home theater, It supports Dolby Digital surround sound , but it has no digital ports what so ever , the only way to produce Digital surround right now is from a DVD/CD or ?USB flash drive?. I want to connect the 3x 3.5 aux connections for PC somewhere on the LG HT356SD-s board, I want to know if that is in any way possible?
AMPs : 2x http://www.ti.com.cn/cn/lit/ds/symlink/tas5342la.pdf
Stereo Audio ADC : https://www.cirrus.com/en/pubs/proDatasheet/CS5346_PP3.pdf
I tried connecting one aux cable to the CS5346 (right to PIN 12, left to PIN 11, ground to PIN 13) and feeding a signal from the pc through the aux cable but no luck , i also tried it in every single mode ( Tuner, Aux, Portable, CD/DVD etc.)
AMPS
http://i.imgur.com/a7d6jNt.jpg
http://i.imgur.com/dMi6qG4.jpg
CS5346
http://i.imgur.com/jHd8gqw.jpg
Miscellaneous
http://i.imgur.com/dG3R7sm.jpg?1 (the 20 pin port is connected to the DVD/CD reader)
http://i.imgur.com/Ga3f0b0.jpg
http://i.imgur.com/CkYePLH.jpg
http://i.imgur.com/EaFVVn2.jpg
http://i.imgur.com/oGxpaVw.jpg
http://i.imgur.com/Dp8jHiG.jpg
AMPS
CS5346
Miscellaneous
