T
Tim Shoppa
I need to convert 48V (actually 54V nom. telco battery voltages) to 12V at
4Amps. Isolation isn't needed. I've looked at the NatSemi Simple
Switchers, but the voltages are real near the high end of the "HV" series
(makes me nervous, I don't like to run active devices just a few
volts from their advertised upper limit for extended periods)
and I think the current is out of range of the HV devices anyway.
Can anyone recommend either a device that is appropriate (at these
currents I may need a power MOSFET, I realize, in addition to the
the switching controller) or an off-the-shelf box that does this
conversion?
I should add that the off-the-shelf box has to be under $100 or so. I've
found some telecom suppliers that sell appropriate capacity DC-DC converters
but they seem to start in the $400 range!
Tim.
conversion?
Tim.
