E
Eeyore
jonpi said:again ... SpinRite is the killer ap ... it low level formats or "renews"
the disk without hurting data ...
Can you tell me more about that ?
Graham
Eeyore said:Can you tell me more about that ?
Graham
Hi Graham..
The emphasis on "low level" format... we haven't done that since
back around the time sunshine was invented.
Thank goodness
it is true that sometimes your drive will not work with a different
controller...the only way to know without having unavailable info is to
try it...beware as in many cases if you are trying something, do not do
anything like chkdsk since then you are not only trying, you are changeing
the reason is that the low level format program is on the bios of the
controller ... when you set up a disk you use the debug comand to run
the controllers "setup" program which low level formats the drive and i
guess the partition is set too... then it is ready to do the regular
high level format with DOS ... different controllers had slightly
different parameters sometimes so you can't just switch and expect to
read the drive set up on another type controller
the thing is that these drives lose the low level format over time ...
that is where spinrite allows you to
redo it without saving the data and putting it back
WD 300 ... does not ring a bell ... WD1003 does
and your drives are double spaced or single spaced, whatever one was the
little used format ... that does complicate things ... again info that
is in the past as far as my brain goes ... sorry
conflict. There was a great website called "The Ref (tm)" with a lot of
mirrored sites, but I can't find any of them that still exist.
A guy called Steve Gibson wrote it in the '80s. He's online these
days: <http://www.grc.com/sr/spinrite.htm>
If you actually need one of the older versions that worked on MFM &
RLL controllers, it'd probably be worth dropping him a line.
jonpi said:yes .. The Ref was the killer site ... back in the mid 90's
Try this site if its not too lateclifto said:I found a Simtel mirror at http://ftp.univie.ac.at/mirror/simtelnet/
but I can't remember which directory tree TheRef was in. Don't know how
recent their copy will be. Simtel itself doesn't give results for a
search on "theref".
