45 amp Battery looking to prevent arc flash.
Discussion in 'Power Electronics' started by DanielG, Aug 16, 2020.
  1. DanielG
    DanielG
    Aug 16, 2020
    New to electronics
    What type of connector to a 45 amp battery cable can I install to prevent arc flash?
    Also anyone have a clamp connection suggestion for this level of power to reconnect a cut wire instead of solder.
    thank you!!
    Daniel
  2. Kiwi
    Kiwi
    330
    79
    Jan 28, 2013
    What is the application?
  3. Bluejets
    Bluejets
    4,154
    880
    Oct 5, 2014
    You cannot prevent arc flash only limit the effects.....depends what load current you are looking at as to whether or not any arc barrier contactor or solid state switcher is necessary.
  4. Minder
    Minder
    2,985
    633
    Apr 24, 2015
    You could try a suitably sized magnet close to the contacts, acting as an arc blow out as fitted to many high current relays.
    M.
  5. Kiwi
    Kiwi
    330
    79
    Jan 28, 2013
    Another first time poster disappeared into the wide blue yonder?
  6. Harald Kapp
    10,223
    2,204
    Possible, but too early to say definitely.
  7. Tha fios agaibh
    Tha fios agaibh
    2,106
    708
    Aug 11, 2014
    I don't think your concerned with Arc flash unless your talking about a battery bank with voltages exceeding 100v.
    Short circuit protection? Perhaps a fuse or fusable link.
    Compression lugs covered with shrink tubing are ideal for many applications.
  8. DanielG
    DanielG
    Aug 16, 2020
    Its a electric surf board.
    with a 45 amp battery that makes a small pop noise when connecting the battery. See attached connector. . Batteryconnection.jpg Batteryconnection.jpg
    Thank you.
  9. Bluejets
    Bluejets
    4,154
    880
    Oct 5, 2014
    Turn it off before plugging it in then.....
    (*steve*) and Martaine2005 like this.
