433MHz remote powerplug - Copy the remote
Discussion in 'Electronic Basics' started by Jan Nielsen, May 26, 2007.
  1. Jan Nielsen
    Jan Nielsen Guest
    Ok, topic may seem like I want to copy someones design, that is not the
    case.
    I want to trigger the radio controlled powerplugs without using the
    remote, so I can integrate it in my own hobby projects, to make a safe
    230Vac relay.
    I have a 433MHz remote power system which works fine.
    I would like to act as the remote with a PICAXE and a tx module.
    I have already tested that I can recieve something when the remove is
    pressed to make sure its the same freq.
    My biggest problem is how to determine what is the correct baud rate,
    and how many bytes to recieve at a time to read what it sends.
    The remote is a SARTANO one, with no real model info on it, the printing
    circuit says KT6899TX.
    Alternativly I can mod the remove to trigger it, but the fake sender
    would be a neat project.
    Any hints would be nice.
    Jan
