4017 IC
Discussion in 'Microcontrollers, Programming and IoT' started by Tinker Unique, Aug 12, 2018.
  1. Tinker Unique
    Tinker Unique
    22
    Dec 1, 2014
    Hobby project = I have a sequence blinker in mind and have the 555 IC, and need to get a 4017 controller, Also wanted are 12v "micro-lights" to power the project or LED's that broadcast light instead of 'narrow beam'. Since Radio Shack is no more, where can I get such lights ? Will need a dozen red and about 4 yellow. They will be used on a vehicle (12v.)
  2. 73's de Edd
    73's de Edd
    2,872
    1,216
    Aug 21, 2015
    " GOGGLE "
    " Suppliers of grain of wheat lamps "
    or
    " Suppliers of Red and Yellow LED's "
    And that will confirm that Rat Shak wasn't the SOLE supplier on earth, of those two items . . . .hmmmm.
    Richard9025 likes this.
  3. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    You will need current limiting resistors for the LEDs too.
  4. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    You will need driver transistors; the CD4017 outputs can only source or sink a few mA. I'd probably use 2N7000s.
  5. Audioguru
    Audioguru
    2,826
    633
    Sep 24, 2016
    The datasheet for the CD4017 shows that with a 12V supply (14.4V in a vehicle) its output current into a 2V red LED is typically 27mA which is enough to smoke its output transistors. (14.4V - 2V) x 27mA= 335mW in each output transistor but the max allowed dissipation in each output transistor is only 100mW. With 240 ohm current-limiting resistors then the current can be 18mA and the CD4017 will not overheat.
    I harvested LEDs of many colors that have a very wide 180 degrees viewing angle from Christmas tree LEDs that people threw away. The top of these LEDs is dented and not round and I have never seen them sold in electronic parts stores.
    kellys_eye likes this.
  6. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    That's fine if and only if the O.P. doesn't intend any parallel connection of his "dozen red and about 4 yellow" LEDs. I usually assume a reasonable, delimited for hot weather, design current for the CD4017 to be ≈15mA at 12V.
    Inverted cone, also known as straw hat, helmet, dented lens, etc. LEDs are readily available new.
  7. Tinker Unique
    Tinker Unique
    22
    Dec 1, 2014
    Am familiar with the "dimpled" LED's and the broadcast light. Have found them (4.5 v DC) at places like Michael's and Hobby Lobby - powered by 3 AA batteries. Also know that 12v. LED's (Christmas & regular) can be found at many truck stops. The "inverted cone" can also be made with a Dremel, and a slight coat of clear fingernail polish - it works IF careful = (wooden clothes pin holding the LED in a vise and Dremel drill press with wood router bit) I have a habit of thinking "out of the box" and it usually works
  8. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    Your approach to sourcing seems very limited. Unless you have to complete this project in less than 1 week or you just want to tinker as your username may suggest, there's no reason to "carve" your own LEDs or buy expensive, non-optimal devices at local retail stores. We have a resource here that may be useful to you.
    https://www.electronicspoint.com/resources/component-suppliers.34/
    Why not plan and execute the project in a slightly more formal way: defined result, mechanical and electrical design, process steps, bill of materials, etc?
    In my experience, the phrase "out of the box", while intended to convey a claim to superior creativity, is actually used to rationalize abusive, immoral, unsafe, unethical and/or illegal action and conceal an actual creativity deficit.
    davenn likes this.
  9. Doug3004
    Doug3004
    119
    23
    Sep 5, 2014
    Can you post a link?
    Regular 5mm/3mm LEDs have a hemispherical top. Those are easy to find.
    Straw Hat LEDs have a rounded convex top. It is not flat, but not nearly a hemisphere either. Those are easy to find also.
    The Christmas tree LEDs have a concave round cone top.... I am another who has only ever seen these LEDs on strings of already-manufactured Christmas tree lights. Does this type have a name? It may be that the LEDs are encapsulated like that by the companies that make the strings of lights. Or maybe it is just a plastic lens held over a normal 3mm LED? I've never taken a Christmas-tree LED apart.
    This page has a close-up picture of one, about 2/3 of the way down the (long) page:
    https://www.aliexpress.com/item/Min...ome-Shopping-Mall-Decoration/32892845192.html
  10. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    Okay, I'll humor you. Here's one. After this, you have to find your own. ;)
    https://www.moreleds.com/whiteinverted.htm
    davenn likes this.
  11. Audioguru
    Audioguru
    2,826
    633
    Sep 24, 2016
    Some of the LEDs in my solar garden lights have a very short clear case with a rounded top that has the chip very close to the top. Then its light is VERY wide angled.
  12. shrtrnd
    shrtrnd
    3,734
    478
    Jan 15, 2010
    I'll tell you what. I think of something I want, start researching the circuit that will get me there, then start looking for the parts, .... hours later I find what I need already fully assembled and for sale for $9.99 on eBay.
    Are you sure you don't want to just look for somebody who already invented what you want and is selling it cheap?
  13. Tinker Unique
    Tinker Unique
    22
    Dec 1, 2014
    There is NO intent to do anything abusive, immoral, or illegal. I have wanted to finish this "project" for over a year. Finances have been a bit strained and I'm just asking for more specific info on parts/components needed. I have a schematic on the original plan, and am trying to confirm the parts needed to complete the 'project.
  14. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    I was just reacting to a phrase that irks me, not accusing you, though you didn't deny unsafe, unethical or creativity deficit. ;) I have a pet peeve about platitudes.
    I've done a few 555/4017 sequencer projects before. You didn't say what your plan was, just wanted a source for wide dispersion LEDs. For sourcing help it's useful for you to update your user profile with a location. Do you have what information you wanted for your project or is something still needed?
  15. Tinker Unique
    Tinker Unique
    22
    Dec 1, 2014
    What I meant by "out of the box" has nothing to do with being superior or arrogant. I was referring to "out of the box" as being different and unique ( NOT ordinary) I like things a bit different , like making lighted ash trays... OR making a teeter totter for a couple lighted snowmen (purchased) in the front garden at Christmas time, that runs on a 12v. system. OR making 7" butterflies for a water garden that have moving wings (clockworks)..
Similar Threads
Loading...
