4017 Different LED count
Discussion in 'General Electronics Discussion' started by bigkim100, Jun 8, 2021.
  1. bigkim100
    bigkim100
    98
    Apr 17, 2013
    Any way to get a 4017 (Driven by a 555) to count down rather than up. can this be switchable from counting up, to counting down LEDS?, or will I have to use something different than a 4017?
    Thanks in advance for any help
  2. PETERDECO
    PETERDECO
    174
    40
    Dec 19, 2019
    I believe the 4017 only counts up and returns to 0. A microcontroller, such as a PIC, can be programmed to do what you want and eliminate the need for a 555 in the process.
  3. bigkim100
    bigkim100
    98
    Apr 17, 2013
    I dont know how to do programming for microcontrollers
    Is there a way to do it sans Microcontroller
  4. Martaine2005
    Martaine2005
    3,554
    966
    May 12, 2015
    Not sure I follow this.
    You can put the LEDs in any order you like. Also diode steering for more complex control.
    Martin
  5. bertus
    bertus Moderator
    2,019
    755
    Nov 8, 2019
  6. AnalogKid
    AnalogKid
    2,515
    718
    Jun 10, 2015
    For non-switchable, counting down only, just connect the LEDs differently.
    For switchable between up and down, you will need two chips (besides the 555). One is a 4-bit decimal or binary up/down counter. The other chip is either a 4-line to 16-line decoder, or a 3-line to 8-line decoder. Both are standard CMOS CD4000-series parts.
    ak
  7. Audioguru
    Audioguru
    3,382
    726
    Sep 24, 2016
    Like above, a "Road Runner" circuit uses diodes to steer the outputs of a CD4017 to make a row of LEDs light back and forth.
  8. AnalogKid
    AnalogKid
    2,515
    718
    Jun 10, 2015
    I think that is a "Knight Rider" circuit.
    ak
