Hopefully these pics will show the full set up.
http://a548.ac-images.myspacecdn.com/images01/105/l_9f67b69cc9c5093d7...
This is the inside of the firing box. The barrier strip at the top
brings the +12V and ground for the firing control boards (at bottom)
as well as a separate ground for the igniters that is controlled by a
safety switch. I added the cap to the barrier strip last night in an
attempt to help stiffen the power supply to be boards, but have not
yet tested it.
http://a340.ac-images.myspacecdn.com/images01/79/l_d358560b9c651a8da6...
The second pic is the top side of one firing control board. There are
5 of these in total. The IC at the top is the 4017. The black
rectangular boxes at the bottom of the board are the SPST reed relays
that activate the igniters.
http://a502.ac-images.myspacecdn.com/images01/82/l_86a86c8ec7313a72a4...
The underside of the firing board. The wide trace on the right side of
the board is the +12V and the left side is ground. Are these too
small?
http://a861.ac-images.myspacecdn.com/images01/82/l_5aafdf9e0837402f36...
This is the Kit74 parallel port interface as well as the power
supply. I only have them sitting this close in order to fit them into
one picture. I have wired leads onto the Kit74 that goes to an RJ45
jack. That ethernet cable then goes to an identical jack where each
line is connected to the clock pin of one firing control board.
So in theory the operation goes like this:
The system is powered up and all counters and parallel port are
reset. The ignitor ground is then connected via a remote switch.>From there the software on my laptop plays the soundtrack and at set
intervals activates a single channel output on the parallel port.
That signal is then sent from the Kit74 interface via an ethernet
cable to the firing boards in the display. The 4017 in the firing
controller advances one count, activating the next relay in line. The
wire connected to the relay receives +12v which passes through the
nichrome igniter and returns to ground through the safety switch. The
wire heats, igniting the fireworks. The igniter typically burns up in
less than 1 second. The process repeats until all 9 cues have been
used.
