T
[email protected]
hello, I have a viewsoni N2700w LCD. The power cable that runs from
the VISIONBANK board to power the LCD panel shorted out because the
protective sheath was touching some metal on the inside of the case. I
have linked some pictures of the problem, and if I was able to get a
replacement power cable, everything would work fine. Is there a place
i can obtain this cable, or what do i need to do in order to make the
cable myself?
Could i just cut off the melted 4-pin connector and solder the cables
right to the 4 pins?
I've included pictures of the unit before I took out the cable that's
been burnt, and an image of the cable by itself.
http://www.thejet.net/viewsonic/cable_needed_1.jpg
http://www.thejet.net/viewsonic/cable_needed_2.jpg
http://www.thejet.net/viewsonic/cable_needed_3.jpg
http://www.thejet.net/viewsonic/cable_needed_4.jpg
Thanks for any help!
cable myself?
