Randy said:
Somehow I got it in my head it was 4, but you could be right.
That would explain why I saw some 3 port cards, but no 4's.
Oh, well, a slight readjustment of plans is in order...
From Ralf Browns (int53) listings:
4 are possible , see below.
----------M00400006--------------------------
MEM 0040h:0006h - BASE I/O ADDRESS OF FOURTH SERIAL I/O PORT
Note: the BIOS sets this word to zero if is unable to find more than three
serial ports at the addresses it is programmed to check at boot
SeeAlso: MEM 0040h:0000h,MEM 0040h:0002h,MEM 0040h:0004h,MEM 0040h:0008h
SeeAlso: MEM 0040h:007Fh
----------M00400008--------------------------
MEM 0040h:0008h - BASE I/O ADDRESS OF FIRST PARALLEL I/O PORT
Notes: the BIOS POST routine fills in the parallel port address fields in
turn as it finds parallel ports. All fields beyond the last one
for which a valid parallel port was found are set to zero.
the BIOS INT 17 handler uses these fields to address the parallel
ports
SeeAlso: MEM 0040h:0000h,MEM 0040h:000Ah,MEM 0040h:000Ch
----------M0040000A--------------------------
MEM 0040h:000Ah - BASE I/O ADDRESS OF SECOND PARALLEL I/O PORT
Note: zero if fewer than two parallel ports installed
SeeAlso: MEM 0040h:0002h,MEM 0040h:0008h,MEM 0040h:000Ch
----------M0040000C--------------------------
MEM 0040h:000Ch - BASE I/O ADDRESS OF THIRD PARALLEL I/O PORT
Note: zero if fewer than three parallel ports installed
SeeAlso: MEM 0040h:0004h,MEM 0040h:0008h,MEM 0040h:000Ah,MEM 0040h:000Eh
----------M0040000E--------------------------
MEM 0040h:000Eh - BASE I/O ADDRESS OF FOURTH PARALLEL I/O PORT (pre-PS/2)
Note: zero if fewer than four parallel ports installed
SeeAlso: MEM 0040h:0008h,MEM 0040h:000Ah,MEM 0040h:000Eh"BIOS DATA"
MEM 0040h:000Eh - SEGMENT OF EXTENDED BIOS DATA SEGMENT (PS/2, newer BIOSes)
SeeAlso: MEM 0040h:000Eh"PARALLEL"
