4 LEDs 4 switches
Discussion in 'LEDs and Optoelectronics' started by helix, Jun 19, 2013.
  1. helix
    helix
    Jun 19, 2013
    I need help with a circuit design. I need 4 LEDS set up so each one is tied to a switch but only one can be on at a time and pushing the switch one is tied to has to turn off the other LED. Could anyone help me with this design?
  2. (*steve*)
    25,496
    2,837
    1) Use a bank of switches where pressing one releases the others
    2) Use a series of latches where each button resets the other latches
    3) Use a microcontroller
    Frankly, (3) will be a far simpler circuit and if you have any experience in programming, it should not be too hard to do.
  3. ikram1991
    ikram1991
    43
    May 5, 2013
    Use a microcontroller It will be easy.
  4. helix
    helix
    Jun 19, 2013
    Thanks for the replies. Could you help with what kind I would? I'm thinking I need 4 I/O lines? I should clarify this is for a guitar switching system.
  5. (*steve*)
    25,496
    2,837
    If I were you, I'd look at arduino and picaxe (google them).
    Both are easy to program and will do what you want.
    There's a learning curve for using either, and both have great communities of users.
    If you know any C, go Arduino. If you know any BASIC go picaxe.
    At their core, they are very different and have vastly different capabilities, but for something as simple as this, either will do.
