4 input NAND w/ 2 input NANDs?
Discussion in 'Electronic Basics' started by Shawn, Sep 20, 2005.
  1. Shawn
    Shawn Guest
    Hello all..
    I'd like to verify my thinking here and make sure I'm not missing
    something simple. I have a circuit that requires a 4 input NAND, but I
    only have 2 or 3 input NANDs on hand. If I take each of 2 inputs into
    2 separate NANDs, invert the outputs, and run them through another 2
    input NAND, I'll get the result that I want - low only when all 4
    inputs are high.
    The logic works out correctly, but I'm wondering if there is a
    better/easier way to make a 4 input NAND out of 2 input NANDs, or if
    that's a generally acceptable way of doing it.
    Thanks for any suggestions.
  2. Chris
    Chris Guest
    Your homework answer is correct.
    Chris
  3. Rich Grise
    Rich Grise Guest
    What's "generally accepted" is usually "what works". Also, lots of
    times, "uses what you have on hand". There are very many ways to
    make a 4 input NAND, if you have other logic gates available. Do
    a truth table, or Venn diagram, or whatever they call it, and
    work out some logic equations and see what you can come up with.
    If all you're allowed to use is NANDs, then what you've got is
    pretty much it.
    Hope This Helps!
    Rich
  4. The essence of a NAND is any low input causes a high output.
    You can tie the outputs of a pair of 2 input NANDs with an OR gate and
    make a 4 input NAND. Or you can connect the 4 inputs to a pair of
    AND gates and tie those together with a NAND. If you only have NANDs,
    your way (using 5 2 input NANDS) is the best you can do.
  5. Shawn
    Shawn Guest
    Yes, that helps a lot, Rich. I appreciate the quick response.
    Contrary to what some believe, I'm actually building a circuit, not
    doing a homework problem.
  6. Shawn
    Shawn Guest
    Actually, John, 2 input NANDs is all I have handy. I considered
    ordering 4 inputs from Digikey, but with a $25 minimum for no handling
    charge, or paying $6 for 50 cents worth of parts, it seemed wiser to
    just try and use what I had here. I do have inverters, so I'll use
    those in conjunction with the NANDs, and should only need 3 NANDs and
    2 inverters as I originally spec'd.
    Thanks again for such a quick response. I'll be sniffing the sweet
    smell of solder tonight!
  7. PeteS
    PeteS Guest
    Merely as a comment, you can make anything out of NAND gates (or out of
    NOR gates) - provided you have enough, of course :)
    They're known as universal gates.
    For two input gates -
    A NAND obviously gives Y = NOT(A AND B), but could also be said to give
    Y = NOT A OR NOT B (DeMorgan's theorem).
    INVERT) from the one gate. The same applies to NOR [ Y = NOT A AND NOT
    B, Y = NOT(A OR B) ]
    For a fundamental gate, invert all inputs and outputs and swap the gate
    type between AND <-> OR to implement DeMorgan's theorem.
    Good explanation at Wikipedia
    http://en.wikipedia.org/wiki/Boolean_logic
    Cheers
    PeteS
  8. Kitchen Man
    Kitchen Man Guest
    Indeed. NAND gates also form the basis for software modeling. Since,
    as you say, a combination of NAND gates can form *any* logic equation,
    once one has a successful software model of the NAND, all one needs to
    form any other software logic circuit is a proper multiple combination
    of the original model.
