4-Channel IR Circuit Help! :( - Urgent
Discussion in 'Electronics Homework Help' started by infrared, Apr 25, 2010.
  1. infrared
    infrared
    Apr 25, 2010
    Ok here it is....I have a project in for Thursday, ive been tearing my hair out for weeks trying to get this to work. My problem is:
    Button 1 + 3 moves motor A clockwise.
    Button 2 + 4 moves motors A + B clockwise.
    Motors latch, it should be momentery, stop when button is let go
    It is supposed to:
    The buttons should be momentary
    Button 1 should move motor A one way
    Button 2 should move motor A the other
    Button 3 move motor B one way
    Button 4 move motor B the other
    And be momentary.
    Are my positive wires position causing the problem?
    Will
  2. (*steve*)
    25,418
    2,788
    You've told us what is supposed to happen, but not what actually happens.
    As far as I can see you've implemented an H-Bridge using relays (which incidentally is exactly what my garage door opener uses).
    Have you tested that your IR remote can transmit signals for 2 buttons pressed at the same time?
    Is this your homework? Have you left it too late?
    Why do you want to use 2 buttons when 1 would seem to suffice?
    Relay 1 and 3 make sense. Are relay 2 and 4 for a second motor?
  3. infrared
    infrared
    Apr 25, 2010
    It is degree c/w. The intended result was:
    Switch 1 rotates motor A left
    Switch 2 rotates motor A Right
    Switch 3 rotates motor B left
    Switch 4 rotates motor B Right
    It is to opperate a household spotlamp to aim to any point in the room.
    what actually happens is:
    Switch 2 rotates motor A + B left
    Switch 4 rotates motor A + Bleft.
    Im not sure if the positive off the relay is going to the correct point. It has to got to a positvie so I stuck it to the closet 6v
    Will
