R
Rodo
Hi all...
I'm trying to convert a 4-20mA current to a voltage I can use with an MCU. I
thought a simple 250 ohms resistor could do the job but it didn't .... the
voltage across the resistor is fine (5v). The problem is with respect to the
common GND of the rest of the circuit, the resistor terminals are at 32v and
27v.
I can not load the 4-20mA line with any more resistance or divert any
current to GND. I tried an optoisolator but the 4mA is enough to turn on the
LED so I get very little voltage swing at the output (phototransistor).
I thought of an op-amp but I can't think (or find) the right configuration.
Any suggestions ?
27v.
Any suggestions ?
