4-20mA to usb/serial
Discussion in 'General Electronics Discussion' started by liambrett, Sep 4, 2009.
  1. liambrett
    liambrett
    3
    Sep 4, 2009
    Does anyone know of a device and accompanying s/w which takes in a 2-wire 4-20mA signal then connects to computer via serial or usb, and a piece of software which will display the value scaled over a given range?:confused:
  2. tron-ee
    tron-ee
    12
    Sep 11, 2009
    Hello liambrett,
    See:
    www . dataq . com /products/startkit/di148.htm (remove the spaces)
    This gadget is an analog to digital converter, $50, (with drivers), is powered by the USB data bus. Shunt one of the analog inputs with a resistor and then you stick the resultant data stream into an Excel spreadsheet for readout, where you can scale the data into the range you desire. 4 - 20 ma
    Remember, Ohm's Law = E over I x R....
    E
    I | R
    Make the above on a peice of paper, stick your finger over the letter-function you
    need to know. Above the line you divide the bottom into the top, below the line, you multiply I x R = E, stick your finger over R, you divide E / I = R, etc.
    E = Potential in Volts
    I = Current in Amperes (or mA...4 mA = 0.004 Amp)
    R = Resistance in Ohms
    So, lets say you shunt an input with a 100 Ohm resistor,
    4 mA x 100 = 0.4 Vdc
    20 mA x 100 = 2.0 Vdc
    This should do it for you.
    tron
