Jim
I need a 4-20ma loop to 0-5 volt converter to interface a sensor to a data
logger. I do have a BB RCV420 chip which does just that, but it requires a
dual supply of 12-15 volts (minimum), and I need to keep things simple and
light because it will be used in the field away from power.
Is this the best way to go on this, possibly with a couple of small 12 volt
smoke detector batteries, or is there a simpler way using an op amp that I
can have a single supply....possibly a 9volt transistor radio battery?
The equipment needs to operate for 6 to 8 hours continuously, without
interruption for battery changes. My data logger has a 5volt supply output
if needed, and my loop sensors use 12 volt battery supplies.
