3D CAM, servo or stepper ?
Discussion in 'Power Electronics' started by skenn_ie, May 24, 2020.
  1. skenn_ie
    skenn_ie
    31
    Sep 7, 2009
    Hi. Having just bought a 3D measurement machine with a working volume of about 1m^3, for conversion for additive and conventional machining, I would appreciate some advice. The machine currently has 3 servo-motors with tachs and position strips. I intend to use an Arduino to control position, but should I replace the servo motors with steppers, or stick with the servos ? The machine came with a minor accessory, superfluous to my requirements, a Renishaw PH10M and TP20 std force probe.
  2. Harald Kapp
    10,545
    2,349
    Servo + position sensor should be good. The advantage is that you always know the exact position thanks to the position strips. You don't have to worry about finding the origin after power up or about missing steps.
    The "disadvantage" is that you'll have to evaluate the sensor data from the position strips.
  3. KMoffett
    KMoffett
    720
    73
    Jan 21, 2009
    Unless the strip is an "absolute" position encoder, you still have to relocate the origin on power-up.
  4. Harald Kapp
    10,545
    2,349
    Of course, you're right. I implicitly assumed the encoder to be of the absolute type. I inferred from the "position strips" - incremental strips do not give an absolute position.
  5. skenn_ie
    skenn_ie
    31
    Sep 7, 2009
    Absolute of incremental, I don't yet know, but even incremental will avoid missed steps (of steppers) under load.
