36vdc to 24vdc step down power supply
Discussion in 'Beginner Electronics' started by Monte, Feb 1, 2004.
  1. Monte
    Monte Guest
    x-posted:
    alt.binaries.schematics.electronic
    alt.electronics
    I need a 36vdc to 24vdc step down power supply of some sort for a CNC
    Servo motor control to test/calibrate my servo drivers. Does anyone have
    a schematic I could use? I'd like to be able to run down to Radio Shack
    and get the parts if possible, so I guess simple is better.
    Monte
  2. Mark J.
    Mark J. Guest
    In news:6FdTb.31797$ (Monte):
    Well, it all depends on how much current you need. This site has some
    unique and simple bucking regulators that might be adaptable to your needs:
    http://www.romanblack.com/smps.htm
    To drop 12V using a linear regulator would waste a lot of power as heat and
    require bulky heatsinks. A switching-type regulator would be much more
    efficient.
  3. Monte
    Monte Guest
    Thanks Mark,
    I forgot the current part. Might be up to 20A. I'll check out the web
    site you gave.
    Monte
  4. Monte
    Monte Guest
    Thanks Mark,
    site you gave.
    Monte
  5. For short tests use a couple of 12V car batteries in series.
    Cheapest way.
    Ghost Chip
  6. dont know
    dont know Guest
    There are dc-to-dc converters available. 48v dc convertes have an
    input range of 36vDC to 60vDC. you will have to google for
    them.
