It's also possible to go beyond the stated limit of the USB
spec IF the high-speed mode ("high-speed" in this case
being the full 12 Mbit/sec rate of the original USB 1.0 spec,
not the USB 2.0 rates) is never used and the link is restricted
to just the 1.5 Mbit/sec slow rate. But while it would work,
it's not technically compliant with the 1.0 spec, which I believe
required all USB cabling to handle the original max. speed.
And to compound the situation, the USB 2.0 spec was designed to work
with USB 1.0 cables, which means that any cable that doesn't meet 1.0
spec will not work at the 480 MB 2.0 speed, which is 40 times faster
than 1.0.
What irks me is that the stores are pitching these "USB 2.0 cables",
which is as much marketing hype as the "Digital speakers". If the
cables simply meet USB 1.0 specs, they will work at 2.0 speed.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it:
http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
