32 khz clock signal
Discussion in 'General Electronics Discussion' started by parkie, Apr 23, 2010.
  1. parkie
    parkie
    Apr 23, 2010
    Hello, i am wanting to know how to clock down a 32 khz clock to 16khz?
    I am not sure if there is a quick and simple way to do this
    reason is i have an amega328 running arudiuno and i am taking it off the prototyping board and putting it into a final product, but i only have a 32 khz or 8 khz clock here with me
    So is there a way to clock down the 32 or clock up the 8?
    or does it matter if i run the amega328 at a faster clock?
  2. (*steve*)
    25,298
    2,736
    If the amega328 (and the software on it) can handle the higher clock rate, then there is no problem.
    Dividing the clock by 2 is the easiest and can be done with a single flip flop.
    Check out this and this.
    There are simple devices that consist of a single D type flipflop that you could use in a minimum of board space. A NC7SZ74K8X is one option (I suggest this only because I have some of them) -- there are many other options.
    edit: OK, 32kHz, not 32MHz. It would be no problem for the amega328, the issue would be if the software was designed specifically for the slower clock speed.
  3. vk5ajl
    vk5ajl
    8
    Feb 1, 2010
    As mentioned above, a D flipflop makes it easy to divide by 2. One commonly available chip is a half of a 74hc74. Connect the inverting output (Q bar), to the D input, the clock to 32kHz or whatever then take the output from either the Q or Q bar output. Perfect divide by 2 and by two again with the other half of the chip if you want.
