32.768kHz effects IIS ?
Discussion in 'Electronic Design' started by Boki, Mar 8, 2006.
  1. Boki
    Boki Guest
    Hi All,
    Why 32.768kHz might effect IIS ?
    "It is a risk to generate the abnormal sound when "32.768kHz" is used
    and IIS is inputted,"
    Thank you very much for your advice!
    BR
    /Boki.
  2. Where did you see this? What is IIS other than the Fraunhofer
    institure, or institute of Ismalic Studies?
  3. John B
    John B Guest
    Don't worry about it, he's talking in riddles again. He really means I2S (Philips Audio Protocol
    from the 1980's) but hasn't learnt to use Google yet.
  4. Boki
    Boki Guest
    I saw it in a specification.
    BR
    /Boki.
  5. Boki
    Boki Guest
    Coffe or tea?
    Take easy :)
    BR
    /Boki.
  6. Iwo Mergler
    Iwo Mergler Guest
    A bit of context would be helpful. For instance, the specification
    of which device said that? Sounds like a bad translation from Japanese...
    My guess is that your I2S device can be run in a power-save mode
    at 32 KHz but can't input I2S in that mode. CD quality I2S has a
    clock rate beyond 1 MHz.
    Regards,
    Iwo
