300V emitter follower
Discussion in 'Electronic Design' started by Martin Donald, Feb 17, 2006.
  1. Are there any special design considerations for using a simple
    Darlington emitter follower to drive a resistive load at 300 1AV?
    The signal is a 30Hz (not KHz) sinewave at audio line level.
    Given the low frequency, what would be a bombproof transistor to use
    for the 300V rail?
    Regards,
    Martin
  2. What 1AV ? How much is that resistive load?
    What sense does it make to drive a darlington with a sinewave at
    audio line level? How much is that anyway? 500mV ?
  3. Fred Bloggs
    Fred Bloggs Guest
    At those V-I levels, it is worth creating a collector circuit I_V load
    line upon which you superimpose Pmax and SOA limit curves derived from
    the transistor datasheet.
  4. Pooh Bear
    Pooh Bear Guest
    What's an AV ? Do you mean a VA ?
    What's the load resistance/impedance and the signal amplitude ?
    Graham
  5. Phil Allison
    Phil Allison Guest
    "Martin Donald"
    ** The question as posted is nonsensical.
    Try explaining your need in simple language.
    It is obvious that technical terminology is beyond you.
    .......... Phil
