L
Lord Garth
spudnuty said:3 way switches have 3 terminals: a common and two non common. The
common is wired to the load or to the hot. The two non commons are
wired between the 2 switches via two wires, usually black and red. When
the load is activated there is no potential between the common and non
common 1 (shorted) or non common 2 (no connection), nor between the two
non commons 1&2 (one is active the other no connection) When the load
is off a potential appears between the two non commons 1&2 since one
will carry the hot and the other will be connected to neutral through
the load.
The neon and series resistor will be connected between non common 1&2.
Typically they draw .5 to 3 ma so when you connected your meter it
caused the neon to light but dimly. The resistor is usually 19k to
220k.
Richard
You're describing exactly what I drew...I just don't know what kind of a
load
a DMM set to volts and placed in series does W.R.T. the neons. I not going
to test it either!!!!
