Greatvalue1
- Jul 26, 2012
- 13
- Joined
- Jul 26, 2012
- Messages
- 13
I am trying to use a 3 digit panel meter that only reads +volts to read negative volts (It has the 3 wires in the back. 2 to supply and 1 to probe). I am currently using a tl082 op amp as an inverter; However... The power supply I'm using outputs more voltage than the input supply.
i.e. (3A 12.6 V Transformer supplying a duel output power supply using 337 & 317t regulators, giving me @16 volts out @1.5A).
So even though I've managed to invert the 337's output to +, it can only show 12.6 volts max at the meter since the +vcc and -vee on the tl082 is only 12.6V. I'm not asking the circuit for more power, just more volts; enough to power the tl082's +vcc.
(If this sounds weird, you can see the schematics at Jameco JE215 Adjustible Power Supply Kit).
How Can I increase the Voltage to the tl082 +vcc so the meter will read up to 16V?
Or... Is this even possible?
ps. I will consider purchasing a new panel meter only as the very last resort. My intention is to repurpose the stuff I already have.
